We will be replacing all our CAD workstation this year including monitors supporting UHD (4k) resolution. We just had first one configured. And here is the problem – AutoCAD 2016 is not doing very good job scaling fonts, dialog boxes etc. “Start” screen is completely not able to scale in 4k resolution. We use 4K, 3840 X 2160 resolution (UHD), 60Hz on U28D590D - Samsung UHD 28” Monitor. Standard HD resolution (1080p) works perfect. Are you planning to address this in some future service packs or fixes?
@pendean wrote:
@Anonymous your primary business software/tool is AutoCAD through 2016, @jggerth comments are totally valid. Other uses and benefits of UHDTV are irrelevant to this discussion really 🙂
So what you're saying is people who write code, for example, have no business using AutoCAD, correct? I'm sorry but this all sounds like covering up the deficiency of the software by suggesting, "Nobody wants to do *that*!"
Nope, bought it brand new from Amazon.com! Though the price has gone up since then, you can still find great big 4K displays in the $500-600 range...
@Anonymous wrote:
$440 for a 50"?
Was this a back of the truck special?
Sent from my iPhone
@Anonymous wrote:
$440 for a 50"?
Sent from my iPhone
@Anonymous wrote:
$440 for a 50"?
Sent from my iPhone
A quick search revealed this deal.
Also, not a problem to switch resolution to HD for issues like the one under discussion here.
@Anonymous wrote:
$440 for a 50"?
Sent from my iPhone
@jpryne wrote:
@Anonymous wrote:
$440 for a 50"?
Sent from my iPhoneA quick search revealed this deal.
You get what you pay for. I highly doubt those will last more 3-4 yrs.
@jpryne wrote:
@Anonymous wrote:
$440 for a 50"?
@pendean wrote:
@Again, out of context: your response is valid for your scenarios, @jggerth response for the topic of this thread.
No cover up, no conspiracy, you seem passionate about a topic that has nothing to do with the display limitations of the current crop of AutoCAD products.
Off topic? What topic are *you* discussing? The rest of us are discussing the fact that AutoCAD2016 is unusable at 4K-resolution. The response, "Bah, nobody needs 4K resolution," is as unprofessional as the original problem.
Well, I did get a 4-year warranty, and if I get 4 years out of this monitor, I'll consider it money well spent.
Fine, perhaps I'm out on the fringe advocating large, high-resolution displays, but such is hardly a new trend, and AutoCAD is falling behind the curve.
I just purchased a Surface Book (i7 6th gen), Here is what Microsoft says about this computer, "Want to run Adobe Creative Cloud, Citrix, AutoCAD or Visual Studio? No problem. Surface Book runs all of the professional-grade software you need with no compromises" BIG compromises as the 3000 x 2000 (267 PPI) screen resolution makes a mess of the text and other issues as earlier mentioned. From the comments, it sounds like I just might wait for the next AutoCAD upgrade as it seems a patch may be unlikely. Fortunately, I will only be using the monitor while traveling, but it appears docked to a dual monitor that I now use is the only way to get 2016 to work properly. By the way, my OPINION is that 4K is here to stay (not like 3D or Betamax). One look at a 4k MONITOR and you'll notice the difference. TV's are a different story and I agree may be a fad until the price reaches the cost of LCD screens. So PLEASE TELL ME AUTODESK IS GOING TO PATCH 2016 TO WORK WITH THESE HIGHER RESOLUTION MONITORS!
I just hope you didnt purchase a 4k Gaming GPU to run AutoCad on... lol
Cause that would make no sense at all >.<
Ah, yeah - only a nutcase would buy a $3000 computer to play games. I am an engineer - purchased the Surface Book for speed and portability (it's VERY light). My Dell M6700 workstation is VERY heavy. The charging "brick" weighs more than the entire Surface Book. However, today I received my docking station and tried to run AutoCAD 2016 on my dual Dell U2410 monitors. NO WAY JOSE. the scaling is a HUGE problem. Part of the issue is with AutoCAD - the command line is HUGE and extends into the model space. The other issue is definitely an issue with the monitors. Once I reduce the size of the window to approximately the size of the Surface Book's screen, the drawing is fine, however, enlarging it to the full 24in causes imaging issues. I attached a screen shot of the issue. You can see the command line is HUGE and the bulk of the drawing is missing.
I'm considering sending the darn thing back - good that MS offers a 30 day return policy.
You are correct about the Surface PRO, but the new Surface BOOK is a real machine. The i7 6th gen processor is faster than my M6700 workstation and with 16GB of RAM it outperforms the workstation and is MUCH more portable.
You forgot to mention "while skipping rope and doing a hula"...try that from your iPhone
