3DS Model to 2D Linework in Autocad
brodie.mclean
Message 1 of 9
brodie.mclean
I have a detailed 3D model of a Tracked Dump truck in 3DS Max that I ultimately want to create top/side view profiles in AutoCad for other drawings. I want these profiles to be 2D linework that are exactly the same as the 3D Model when in a “Hidden” view style.
I am using AutoCad 2020 and 3DSMax 2020. I have tried a few things to no avail. Any help would be appreciated.
Attempt #1: Export from 3DS Max to dwg file and open in AC. The 3D model is now a mesh. Switch to Top View. Use flatshot command. Process is very heavy and takes overnight. I end up with 2D linework but it contains all of the Lines that I want to be hidden. There are too many lines to delete manually.
Attempt #2: Export from 3DS Max to dwg file and open in AC. The 3D model is now a mesh. Switch to Top View. Use flatten command and select YES to remove hidden lines. Processing time is way too long and doesn’t finish.
Attempt #3: Export from 3DS Max to dwg file and open in AC. The 3D model is now a mesh. Switch to Top View. Change view style to Hidden and the plot the layout to pdf. Try to use pdfimport to reimport the pdf, but the 2D view is a raster image and not 2D linework.
Any help would be appreciated!
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
I suspect your problem is you are leaving everything not related to the 2D view you want in place and expecting AutoCAD to do the cleanup for you automagically.
Try this: go back to Attempt #2, when in AutoCAD, erase everything not relevant for the "2D view" you are trying to capture (aka below that 2D plane), then FLATTEN.
HTH
Message 3 of 9
brodie.mclean
I would do that but the mesh created in the dwg export is large and that to delete non-relevant mesh-work would be impractical... I have attached the dwg file exported from 3DS Max.
Message 4 of 9
TerryDotson
Attached is a small 1mb shot in the dark side view.  If you can use it great, otherwise it didn't cost you anything.
Seems like there should be a good way to do this sort of thing.
Message 5 of 9
brodie.mclean
That's what I'm looking for yes. How did you do this? I have many other models I want to do this to as well...
Cheers,
Message 6 of 9
TerryDotson
Sadly it's a hack, but a fast one.  I plotted to a high resolution PNG raster then vectorized it.  I believe I can get a little better results, still trying.  Drop me an email dotson (at) dotsoft (dot) com so I can email it and not pollute the forums with various attachments.
Message 7 of 9
skintsubby
Hi @brodie.mclean
Try using FLATSHOT but don't tick the "Obscured Lines" check box. This should do your view without all the hidden lines showing.
Mark
Message 8 of 9
brodie.mclean
I've tried this, but the 3D model is too large and this process take far too long.
Message 9 of 9
Liubomyr_H
For those needing to generate complete drawing packages (2D DXF for AutoCAD, vector PDFs, isolated detail sheets, and automatic BOM tables) directly inside 3ds Max in 2 clicks, feel free to check out AlphaButton Drawing Generator.
There's a 14-day free trial available here: 👉 https://www.patreon.com/AlphaButton/posts/alphabutton-161773361
