AutoCAD 2012. When I change graphics settings by command line "3DConfig" or by the GUI, the settings keep for that session but reset after I close AutoCAD and reopen it. I have tried saving a profile, but I don't think these settings are included in the profile.
What may be causing the settings to reset? How can I fix this?
Further background info:
My AutoCAD launches with hardware acceleration turned off and two invalid 3DConfig variable settings. The Adapative Degradation "Degrade when FPS is below" setting is 0 and the GUI will not accept any changes, I have to change this by command line. Also the Dynamic tessellation "Number of tessellations to cache:" setting is 0, requiring a change by command line as well. After changing these two variables to valid positive integers, I can use the GUI again to enable hardware acceleration.
I have to repeat this drill every time I open AutoCAD though.
My company has a managed silent install which gives me no visibility into that process. I am also unable to run anything as an admin.
Thank you for the quick reply.
AutoCAD would revert to invalid setings (i.e. set two options to 0 that must be a positive integer) because of my hardware config? This throws errors when I try to open the Perforance Settings GUI, so I must make these changes by command line.
My Quadro 1000M is AutoDESK certified and recommended.
My admin has me on driver 332.21 and I cannot change this, but it is newer than the AutoDESK recommended drivers.
What other possibilities are there?
Has Autodesk made any improvements to this faulty feature since 2016? I am still having this problem, and found this thread in response to my Google search. Is there not a way to override their "best guess" and hard-set the 3DCONFIG settings to your personal preference? It keeps reverting back to settings that cause my program to act insane.
Your answer is "no, they haven't fixed this faulty feature" then.
It IS faulty, because my hardware IS compatible. The software is changing settings to ones that are not ideal. This should not happen. There is no reason I can't determine this setting like every other system variable. None of the other system variables randomly change to something I didn't ask for. There is no excuse for this.
