AutoCAD Forum
3d surface convert to 2d contour lines
2 REPLIES 2
2278 Views, 2 Replies
Hi, everybody! I have a 3d model of surface generated with photo scan. I need show is like topography lines with height points.Screenshot_1.jpgrelief_1.jpg
There is some automatic method to do this fast?
Thank you!
2 REPLIES 2
Alfred.NESWADBA
If you have AutoCAD Civil 3D, then yes, you can create contours from a surface.
For Vanilla AutoCAD you need an additional tool to get that done.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thank you, Alfred. You showed me the way )
AutoCAD Inside the Factory
