- Mute
- Permalink
- Report
Hi, I've been having an issue with random 3D solids shrinking by a few thousandths of an inch over the course of a drawing's life. For example, I have 6" wide steel channel extruded at 120" long, with no problems. Then randomly, I notice the channel changes from 6" to 5.9950" in height days or weeks later. This has happened many times since I've started using Autocad 4 years ago, and I've used each year of Autocad version since so I don't imagine it to be an update issue. The height is consistent across the length of the solid. Also, I have not done any presspull or sub-object selection filter modifications to alter the height of the extrusion. Along the same lines, I might have 2 of these extrusions 80" apart and then mirror objects from one channel to the other channel. For a length of time, the objects will maintain being 80" apart, but at some point one of the channel extrusion shifts by .0023" or .0076", etc., so now mirrored objects are 79.9977" apart or something like that when I work with the drawing again. Maximum annoyance.
Any ideas what could cause this?
I uploaded a photo of the extrusion, and a photo of the 2D shape that I extruded from. Right now I don't have an example of the mirroring issue.
Thanks for any help in advance! Patience is appreciated; this is my first post.
