3D model in Autodesk doesn't rotate around axis Y
Message 1 of 23
After export to DWG file from original *STEP file in Inventor 2015 3d model(that was made in Solidworks 2014) when open in AutoCAD 2015, the model rotates around axis X and Z only, so i can't just turn my model to the left and right without 3D rotation function .Please could you answer, how to overcome this problem?
Replies (22)
Message 21 of 23
BrianBenton
@Anonymous wrote:
Thank you , yes Gizmo workspace was set up in that directions i didn't want to.Thank you who also helped on this question.
Great. Since it was the Rotate Gizmo could you mark that post as answering your question please? It will help others know what to do in this situation. It will also let others know the problem has been resolved so they can move on to other posts that still need assistance.
I'm glad we could all help out.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 22 of 23
pendean
Community Legend
Community Legend
Sergie, we are all using AutoCAD 2015 just like you and we cannot replicate your problem. I suspect you don't know how to put the Y-Axis in the correct position first.
I open your file, hold the shift key down+press down the scroll wheel: since your file opens with the y-axis pointing up/down you limit your mouse movement to the X and Z axis. You need to rotate it so the Y-Axis is pointing Left first for example (I did this by moving the mouse down, then left). Now you can rotate around the Y-axis by holding shift+scroll wheen and moving Up/down.
Try it, attached is where I repositioned your Y-Axis.
Message 23 of 23
Thank you very much!
