I am busy with a 3D drawing and an issue is causing problems.
Items randomly change position, but the correct position can still be selected but this also selects the moved item.
Am I doing something wrong?
I am using Autocad 2014
Any assistance will be appreciated.
Thanks - stay safe
Barry
Thanks - stay safe
Barry
Solved by imadHabash. Go to Solution.
I'm afraid that you need to install service pack or the update ( maybe ) that can fix this issue . any way follow this link Here and see if it's help .
Imad Habash
Imad Habash
As I live in South Africa and often are away in the bush with water treatment installations, I cannot "upgrade" as Autodesk wants an internet connection every 30 days, so I have to stay with 2014.
I am sometimes away from any form of internet connection for months at a time.
I had to search for the SP, but I found it (not from Autodesk) and have installed it.
I will let you know if this fixes the problem.
(Where do I check my package for service pack installations?)
Thanks Imad.
Thanks Imad.
From ABOUT command ( product version ).
Imad Habash
Imad Habash
