3D Display Issues - severe
len.krenzler
Message 1 of 13
len.krenzler
I've never used AutoCAD in 3D mode before (coming from Inventor) and I'm having severe display issues. Objects appear fragmented and triangles jump all over when navigating and performance is terrible. I'm using an Nvidia RTX 3060 on card on Win11. Other software works great (Inventor, AutoCAD in 2D etc).  Things I've tried so far:
Several versions of the Nvidia driver including the latest.
All display modes (realistic, shaded etc.)
Every possible combination of settings in System/Graphics Performance
AutoCAD 2021 and 2023.
Consolidation Mode 0
Any thoughts? Any help much appreciated.
Replies (12)
Message 2 of 13
Patchy
Check to see if your model is not far from 0,0,0
Then see if Graphic acceleration is at fault.
Message 3 of 13
len.krenzler
It does appear to be far from 0.  Is there any quick way to move everything?  Thanks!
Message 4 of 13
Valentin_CAD
@len.krenzler
Try these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 13
Kent1Cooper
@Patchy wrote:
... see if Graphic acceleration is at fault.
[I think you mean Hardware Acceleration, which is an option within the GRAPHICSCONFIG command.]
Kent Cooper, AIA
Message 6 of 13
Patchy
Move, all, pick a point and destination 0,0,0
Message 7 of 13
Patchy
Yes 😁
Message 8 of 13
len.krenzler
Moving it to 0,0,0 did not fix it.  Turning off hardware acceleration did not fix it.  I tried all the suggestions on the previous link.  I'll see if I can get permission to upload the file.  Thanks for all the suggestions but no luck.
Message 9 of 13
len.krenzler
Here is the file I'm having trouble with, if anyone has the time to load and see if it's just me would be much appreciated.
Message 10 of 13
len.krenzler
*edit - I guess this won't work, it seems to have a bunch of x-refs or something.
Message 11 of 13
len.krenzler
Here's the full model.
Message 12 of 13
devitg
@len.krenzler I open in ACAD 2019 , it seem tobe all Ok
Message 13 of 13
len.krenzler
Thanks for trying it. Unfortunately, that's not at all what it's supposed to look like. 90% of it is missing.
