Hi CAD world
I've had a very strange error occur on a drawing. It is displaying as shown in the attached image. The drawings is of about 1000 3D solids not the 100 or so 2D lines shown. The 3D information is still in the file, as they display fine in the Page Layouts. The Page Layouts revert to this same display when I Zoom All, but don't if I zoom out with the mouse wheel. Zooming back in displays these lines.
Thanks in advance
Solved by Alfred.NESWADBA. Go to Solution.
how were the 3D objectes created?
For me that looks like you are seeing the objects from the side, so try command
_-VPOINT 1,1,1
Then you see you objects in 3D .. hopefully 😉
Other option, press <CTRL><A> ... what objects can you see in the property window that are now selected?
Best would be we would be able to look to your dwg-file.
- alfred -
>> Please see attached for my DWG.
Sorry, nothing attached.
To attach files please do not reply by mail, use your Internet Browser to use the attach button inside this site (small paper clip symbol below of the textbox).
- alfred -
well, looking first to modelspace ==> the entities you see is (when zoomed to extents) is just one block.
I have no idea whatfor this block is needed as it has geometry that makes no sense from my point of view.
However, delete that block, then run again zoom extents, now you can see objects which make sense (I hope).
BTW: this dwg-file was edited or created by a none Autodesk product, so it might be important to know which system has created that file to understand the one big block in the modelspace.
That's what I can see now in your drawing:
- alfred -
