AutoCAD Forum
3D connexion Enterprise with AutoCAD 2020
2 REPLIES 2
CDLLT
319 Views, 2 Replies
Anyone able to get the 3D connexion Enterprise to work with AutoCAD2020. Done all the usual updates, driver, re booted, re installed, but all I get is a few minutes of it working,then it stops. Main issue is the rotate just stops and does an odd jump 90 degrees, then rotate opposite direction. If I shut down CAD and re start I maybe get a few more minutes of it work. The thing is far to unreliable to be able to use, not to mention having to wait 2 to 3 days for a response from 3D connexion support.
2 REPLIES 2
pendean
in reply to: CDLLT
Try their public forums while you wait here https://www.3dconnexion.com/forum/
and their support team https://www.3dconnexion.com/service/technical-support.html
CDLLT
in reply to: CDLLT
Update:
So it appears you can't have "Keep scene Upright" toggled on because this does not work with 3D connexion rotate. unfortunately this make controlling the joystick very difficult when working on 3D models of buildings. There is also no fix for this from what I can see, unless anyone knows of one?
AutoCAD Inside the Factory
