AutoCAD Forum
2D Curve don´t want to connect
17 REPLIES 17
Message 1 of 18
StrasakovaAnna221168
989 Views, 17 Replies
i have issue with drawing curve in AutoCad 2D, when I drawing curve there is no way to connect beginning to the end or to some between point. I have all the snapping on, but it didn´t want to connect in any way. I tried looking for solution on the internet, but i didn´t find anything. Is there something i missed ?
This problem makes my projects difficult to draw.
Thank you in advance
17 REPLIES 17
Message 2 of 18
that's not a curve but just a straight pline.
perhaps you post the drawing instead of sharing a png?
Paul Li
IT Specialist
@The Office
Message 3 of 18
Maybe i choose wrong translate for the line, but it is the second icon from the left side. And I share png with screenshot, where you can see that the line donť have connection indicator.
Message 4 of 18
what are your current object snap settings?
have you tried entering endp so that you can object snap to the endpoint of the line segment?
Again share that drawing and not just a png file so we can all take a look.
Paul Li
IT Specialist
@The Office
Message 5 of 18
In my setting i have all icons on.
Yes i tried, objects can snap to eachother when they are done drawing. But when i want to connect them while i draw it´s impossible, this problem came with new version of autocad 2021.
I took screencat, maybe that will help understand ? I upload dwg. if it helps in the top
https://knowledge.autodesk.com/community/screencast/08d14ee2-8693-40fb-81a7-a8b2af5e6965
Message 6 of 18
Check this setting, the MARKER specifically. Run this dialog by the _OPTIONS command.
Message 7 of 18
Yes, I have it same as you. I thought that the problem was there, but it wasn´t.
Message 8 of 18
It's not a drawing.
See THIS if any help.
Message 9 of 18
I checked it and there was nothing new, but thank you.
Message 10 of 18
"Yes i tried, objects can snap to eachother when they are done drawing. But when i want to connect them while i draw it´s impossible, this problem came with new version of autocad 2021."
This sounds like a known issue. You need to get and install all the product updates.
Message 11 of 18
You should not have all the object snaps checked. Clear them all. Then only check endp object snap and try again
Paul Li
IT Specialist
@The Office
Message 12 of 18
I hoped it was the solution, but no.
Message 13 of 18
last resort, close AutoCAD, goto AutoCAD 2021 folder and select: Reset Settings to default
Paul Li
IT Specialist
@The Office
Message 14 of 18
Install all of them and still problem remaining.
Message 15 of 18
If you're on subscription, why not install AutoCAD 2023?  Why do you need to AutoCAD 2021?
Paul Li
IT Specialist
@The Office
Message 16 of 18
I prefer older versions, but maybe i have no choice, just accept the new one. Okey i will do it, thank you, hope the problem will go away.
Message 17 of 18
RobDraw
in reply to: vdpvml
Mmmmmm... Spam for breakfast.
Rob
Message 18 of 18
@StrasakovaAnna221168 wrote:
.... when I drawing curve there is no way to connect beginning to the end or to some between point. I have all the snapping on....
Late to the game, but since I don't see these points made, for others who may have the same problem....]
Does the CLOSE option in the PLINE command [I don't know the wording in your language] not work for you?  It does for me in your drawing.  That's the better way to do it than by picking back on the start point to "close" it, because when you do the latter, you end up with coincident vertices [two vertices in the same place], which can cause problems in some situations.
About the snapping, could it be that you have a lot of object-snap modes set to be applied, but you don't have the choice set to actually apply them?  You need to have this box checked:
[And by the way, since you say you have "all the snapping on:"  I'm not sure exactly what you mean by that, but just so you know, never include NEAREST object snap among the chosen modes.  It will almost always "win" in competition with other modes, and give you unintended results.]
Kent Cooper, AIA
AutoCAD Inside the Factory
