2D barcode font for AutoCAD
caddude1
Message 1 of 15
caddude1
I am looking for a resource with a 2D barcode scanner font, which I can use with AutoCAD. My requirement is for repeatably sized and spaced images of a series of numbers for an optical scanner. I can create (in Adobe) the PDF file; however, the sizing and spacing of imported images (GIF files) become a challenge. The spacing is a critical point, as the product is positioning an AGV in a plant environment.
Mark Behrens
Controls Designer/CAD Manager
42 year AutoCAD user | 15 year AutoCAD Electrical user
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Message 3 of 15
caddude1
Thank you for the link @pendean. I am not looking for a barcode for a DWG file. I am looking for a barcode font to use within a drawing, which will create a 2D code for a numerical value. I have a series of codes that need to be read by a scanner to determine the position of an AGV and fed back for internal processing.
Mark Behrens
Message 4 of 15
DGCSCAD
This one works for what I've used:
LibreBarcode39-Regular.ttf
Edit: Keep in mind you'll need a * as a prefix and suffix, as in:
*12345*
AutoCad 2018 (full)
Win 11 Pro
Message 5 of 15
apotterSJHGL
Observer
Observer
I think what we are looking for a data matrix code, not a 2d bar code.
Message 6 of 15
caddude1
Correct, Andrew. I misspoke on the original e-mail.
Mark Behrens
Message 7 of 15
paullimapa
After creating the PDF from Adobe, just use AutoCAD's PDFAttach command to place the PDF into your drawing at a scale of 1.
https://help.autodesk.com/view/ACD/2026/ENU/?guid=GUID-77D6192C-925B-46A3-8717-240702ED5715
Paul Li
IT Specialist
@The Office
Message 8 of 15
caddude1
@paullimapa I have done so, with success in generating the drawing. My challenge is that AutoCAD puts a complete border around the image. The scanner software fails when it sees the border around the open areas of a matrix. See the attached screen grab.
Mark Behrens
Message 9 of 15
paullimapa
Message 10 of 15
caddude1
@paullimapa That was the first option I tried. I am using AutoCAD Electrical, so that may have something to do with it also. I have tried setting the value to 2 as well with the same result in the plotted drawing. The value that I set the variable to does not affect the drawing. I have found this in multiple files I created to test it out. The attached image is a newly created file, with the value set to "0" as the command line shows.
Mark Behrens
Message 11 of 15
TheCADnoob
My recommendation would be just to get the geometry into AutoCAD natively.
We have a proprietary way of generating QR codes that output as SVG. That said, there are lots of online places that can generate QR codes and output them as svg.
edit: you can use quickchart.io
URL > https://quickchart.io/qr?text=yourtexthere&format=svg
From there, I put it in a third-party application to convert it to dxf. (I use Inkscape, but anything that can convert svg to dxf should work)
Then once its in DXF, I just copy it into the drawing.
It should be noted that our SVG only outputs line segments. So when it first comes in its polylines with no width, so i have to do one extra step of applying a line width to the imported dxf lines.
before adding width
CADnoob
Message 12 of 15
paullimapa
That’s odd. Could you share your pdf?
Paul Li
IT Specialist
@The Office
Message 13 of 15
caddude1
Here is the PDF, SIr. thank you for your time and effort in helping me.
Mark Behrens
Message 14 of 15
leeminardi
Regarding the border,  how about adding a polyline to cover the border?  Set its width to a small value (e.g., 0.1) and its RGB color to  255,255,255.
This prints as:
lee.minardi
Message 15 of 15
paullimapa
I'm using plain AutoCAD 2021 and the PDFFRAME setting is behaving as documented.
The only time the printed pdf shows a frame around the barcode is when PDFFRAME is set to 1
See screenshots & attached dwg & pdfs
paullimapa_3-1760462887610.pngpaullimapa_4-1760462901155.pngpaullimapa_5-1760462916727.png
paullimapa_6-1760462954008.pngpaullimapa_7-1760462976240.pngpaullimapa_8-1760462997352.png
Paul Li
IT Specialist
@The Office
