2027 - toggle button for missing xrefs
w64bit
Message 1 of 8
w64bit
The toggle button for missing xrefs it's always ON when the xref is missing.
How to replicate:
- open a dwg with missing xref
- at the opening, a message appear (One or more references are missing...)
- click open xref palette
- the toggle button is turning automatically on
If I turned off and open the drawing again, the problem is repeating.
In there any variable to use in order to disable this (to turn off for good xref missing toggle button)?
Thank you
Replies (7)
Message 2 of 8
imadHabash
@w64bit
You may need one of the follow:
  • Try the XREFNOTIFY system variable = 0
  • Try the TRAYNOTIFY system variable = 0
Imad Habash
Message 3 of 8
rosie_lucas1
Hey there @w64bit , have you had time to try one of the suggestions @imadHabash made?
If you did, it would be helpful if you mentioned which one worked for you so if another community member was having the same issue.
If you’re still stuck or need more help just drop an update here, and the community will be happy to jump in with more ideas or tips.
Looking forward to hearing from you,
Rosie | Community Manager
Message 4 of 8
asdemeter
I'll help you out.  I tried, and neither works. This is a very annoying feature that was added and forced on us (Shocker.), because in order to fix it, you have to go toggle it off.  Just don't want it.  PLEASE stop fixing what isn't broken.  But for now, nope...we're stuck, and no one will care or fix it, I'm sure
Message 5 of 8
paullimapa
Which toggle button are you referring to?
Can you do a screenshot of it & post it here?
Paul Li
IT Specialist
@The Office
Message 6 of 8
imadHabash
@asdemeter
Can you tell us what your exact problem is and what you did to fix it?
Imad Habash
Message 7 of 8
jreidKVSUZ
w64bit,
Maybe what your wanting is to Keep all your XREF information, even if you don't want them to load.
Try Right Click UNLOAD on the XREF's you don't want to see any ERROR's pop up on you when you open your drawing.
If ever you want them back on live, Right Click RELOAD. See image pasted.
Hope this helps!
Thanks, JRR!
Message 8 of 8
chriscowgill7373
do you have a screenshot of the button you are referring to?  I'm not sure that I know what the toggle button for missing xrefs even looks like (it may be that I've seen it, just never referred to it that way before)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
