2022 - remove Web and Mobile buttons from quick access toolbar
w64bit
Message 1 of 29
w64bit
If you uninstall Web and Mobile using msi from install folder, the buttons inside the program are not removed, like it is in 2021.
If you have at least one drawing opened, the buttons can be hidden from quick access toolbar but if you close all drawings one button is still there.
Replies (28)
Message 21 of 29
nrz13
Unfortunately, it's not located at a similar path. I should have mentioned that in my last post. Thanks anyway.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 22 of 29
arq_gabriel_rmz
Observer
Observer
@w64bit wrote:
How the Share blue button can be removed?
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:40x\CadManagerControl\DisabledCommands
Set SHARE to 1
Message 23 of 29
Anton_Huizinga
That's the one! Thanks 🙂
Only weird that is is set in the local machine and not the current user.
Message 24 of 29
nrz13
Didn't work for me with AutoCAD 2022.  I didn't have a DisabledCommands key, but even after creating it and the SHARE string, it still didn't work.  I tried SHARE with both 1 and 0.
Message 25 of 29
Anton_Huizinga
For 2023 you can set 'EnableShare' to 0 here:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\CadManagerControl\Share
Message 26 of 29
nrz13
Still not working for me in 2022.  I didn't have a "Share" key, so I created that and the "EnableShare" string with a value of 0.  Is there something else I'm missing?
Message 27 of 29
Anton_Huizinga
You are right, it does not work in 2022. My tip works for 2023 only, the reply by arq_gabriel_rmz describes how it works with 2024.
I am not sure if it can be done in 2022, can't find any registry key that points in the right direction.
Message 28 of 29
arq_gabriel_rmz
Observer
Observer
That's right, I forgot to mention that it works in AutoCAD 2024.
Message 29 of 29
cjmcad09
This worked for me. Using ACAD 2025.
