2022 - remove Web and Mobile buttons from quick access toolbar
w64bit
Message 1 of 29
w64bit
If you uninstall Web and Mobile using msi from install folder, the buttons inside the program are not removed, like it is in 2021.
If you have at least one drawing opened, the buttons can be hidden from quick access toolbar but if you close all drawings one button is still there.
Replies (28)
Message 2 of 29
w64bit
How the Share blue button can be removed?
Message 3 of 29
user181
hit the down arrow at the end of the quick access toolbar and uncheck those items
Message 4 of 29
Alfred.NESWADBA
interesting question, it's not part of the quick access toolbar, and it also does not look and feel like a standard menu item. I have not found any possibility to disable or hide it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 29
w64bit
Yes, as I said, the button can be hidden when you have at least one drawing open.
But after you close all drawings, you don't have this option.
Message 6 of 29
user181
I still have option to hide it with no drawings open but even if I don't when I open another drawing it goes away.
Message 7 of 29
w64bit
Yes, you are right. The option is there.
Maybe someone from Autodesk can submit this: when you uninstall Web and Mobile, the buttons are still on QAT.
Message 8 of 29
nrz13
I tried to disable this via the Windows Registry, as some other features can be disabled.  I navigated to version R24.1 > ACAD-5101:409>Applications>CloudAccess and changed "CloudAccess" to "CloudAccessOFF".  While this works for other things, in this case AutoCAD just created a new "CloudAccess" key.  That is probably why it still shows up even after you uninstalled it.  It seems something in the programming is reinstalling it every time the program loads if it can't find it.
Fortunately for me, I don't see the Share button because I have a floating Layers toolbar in that location that covers it up.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 9 of 29
w64bit
Any news regarding a solution for this?
Message 10 of 29
pendean
Community Legend
Community Legend
Autodesk Feedback is here https://www.autodesk.com/company/contact-us/product-feedback
UNDEFINE the commands.
And include a startup that keep them undefined at each startup, then add a reactor that stops their redefining.
Then... train train train your folks that it is against your policies to use them.
OR... roll back to R2021.
HTH
Message 11 of 29
w64bit
Anyone knows if 2022.1 has solved this?
Fix removal of:
- Web and Mobile buttons
- Share button
Message 12 of 29
peterm
Yes, you can get rid of the web and mobile buttons, but there's no way to remove the share one.
Message 13 of 29
w64bit
And after AutoCAD restart the Web and Mobile buttons remain hidden?
If you close all drawings the Web and Mobile buttons are hidden?
Message 14 of 29
peterm
I closed all drawings and the buttons reappeared.
I then hid the buttons with no drawings open and now they don't appear at all.
I haven't tried closing and re-opening AutoCAD yet as I'm having issues with loading profiles and it's a bit of a pain.
Message 15 of 29
nrz13
@w64bitNo, not fixed in 2022.1.  New, Open, Open from Web & Mobile, & Sheet Set Manager all reappear after program restart.  Share button still not removable.
Message 16 of 29
pendean
Community Legend
Community Legend
Are you the Autodesk account admin for your office? You can simply un-assign those features/abilities from each individual user assigned that AutoCAD license, then do as suggested to remove what icons can be removed.
Not much else you can do beyond what is already suggested.
Message 17 of 29
dpattersonnz
Any solutions for removing the share button? I had a quick look in regedit but couldn't find a key to toggle it off. Covering it up with a toolbar is one workaround but I would much prefer a cleaner easy-to-modify GUI. Not a fan of shoehorned sharing shenanigans. Have sent a request to the link @pendean provided.
Message 18 of 29
CivilNJ
for 2023 - found this and it seems to work.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R24.2\ACAD-6100:409\CadManagerControl\Share
Set EnableShare to 0
Message 19 of 29
nrz13
Have you been able to find the correct key in the Windows Registry for 2022 (the subject version of this thread) yet?
Message 20 of 29
CivilNJ
Since I don't have it installed, i can only guess that it should be similar and in the \23.1\ path rather than \24.2\.
