2018: Missing ribbon panels
Allen_Hart
Allen_Hart
We're using the AutoCAD that gets installed with AutoCAD Mechanical that gets installed with Inventor 2018.  There are a bunch of ribbon panels missing. The Annotation panel is missing altogether, and the ribbon does not change when objects are selected. IOW there are no context ribbon panels. Anybody else seeing this?  Is there a sysvar that turns them all on?  I can't find it.
The ribbon seems to work properly in ACADM, but we don't use or need that.
Allen
ara_neresesian
hi
try to change work space to something else ,and see what is changing ,
return work space to your default
and please send a screen pic from your autocad screen ,
also in option go to profile and choose autocad and see the result,
Good Luck
Allen_Hart
I'm using the Vanilla profile. Switching to Acadmpp profile had no effect.
Evidently my saved workspace from 2017 did not migrate properly. When I switch to the basic Drafting & Annotation workspace the Annotation tab appears. And disappears when I switch back. Even so, no context ribbons appear at all. Start the Hatch command and you're on your own.  Same with any other command.
Allen_Hart
In addition to switching profiles, and switching workspaces, I also tried menuunload/menuload, and probably some other fiddling I can't remember. Nothing worked. Then I was reminded of Reset Menus to Default in the Windows start menu, and that did the trick. When I started Autocad, I made sure to UNCHECK ALL migration options. Now all seems to be back to normal. Except of course I have to manually configure all my options, which is fine.
Allen
nicochiarito_pe
Observer
Observer
Hi -
I am having the same issue - I am not following how you fixed this. How do you "Reset Menus to Default in the Windows start menu" exactly?
Thanks.
Alfred.NESWADBA
Here you can find it: >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
