2017 WILL NOT FINISH PUBLISHING
Hello all,
When I go to publish in ACADE 2017 it will not publish. The icon on the ACADE tray says "publishing job in progress" but never come out of that state.
I have reinstalled several time over the last few weeks and the same issue each time.
step to publish:
File....publish (popup box)....add drawings....publish to: plotter named in page setup....publish.
icon on bottom of ACADE says "Publishing Job In Progress" but never changes from there.
Even trying to publish 1 drawing it never comes out of the "Publishing Job In Progress" state.
if i RT click on the project in the project manager,  then publish... plot project....select drawing...do all...ok  it works fine.
i can also print each drawing by itself if i have the drawing open.
Any ideas???
Dennis
dbroad
Turn off publishing in the background (in options dialog).
Architect, Registered NC, VA, SC, & GA.
OK Thanks!!!!
That worked by why cant i publish in the background now?
It always worked in ACADE 2014
Dennis
dbroad
You probably can. It just takes a lot of patience.  It probably assigns a very low priority and may not notify you it's done.  Since I usually publish and check, it doesn't do me any good to background plot.
