2017 Sheet Set Key.reg file needed
dasmus
Message 1 of 23
dasmus
My sheets set manager in AutoCAD 2017 is blank.
The AcSm registry key is missing from R21.0
I see that registry key under R20.0
Is there a file or fix for this like I found for previous versions?
Replies (22)
Message 21 of 23
dasmus
Error log when launching
Message 22 of 23
john.vellek
Hi @dasmus,
This message looks like it might be related to your graphics card. Have you checked to see if an update or rollback of the driver corrects the problem?
You might try the /nohardware at startup to see if that helps too. See AKN Article for details.
The install logs indicate the installation was completed.
I suggest that you add the no hardware switch to your startup and then go through the Diagnositc Windows Startup to see if AutoCAD can then be launched.
Since this is part of a suite, can you please confirm that the other applications are working properly?
John Vellek
Message 23 of 23
dasmus
I'll check to see if there is a graphics card update. Remember that AutoCAD was working fine except for the sheet set issue. It wasn't until I started uninstalling and re-installing that this acadres.dll issue came up. I have not installed the other products of the suite (which I uninstalled as instructed).Confirmed that MEP, Architeture and Raster design fail to launch as well. I will try the no hardware switch as suggested.
