I am using 2017 on Windows 10. I am having a problem with the text size mainly in my print dialogue box. I have adjusted the size through Windows but nothing seems to fix the problem. The ‘Select a Printer’ portion remains so small that I can barely read it even with my face right in front of the screen. Ribbon looks fine, layers pallet, properties pallet; they all look fine. Why is this happening and how do I adjust this?
Solved by john.vellek. Go to Solution.
if you go to other programs like word or excel and try to print do you have the same issue with the print dialog boxes?
CADnoob
CADnoob
Hi @Anonymous,
Do you perchance have a hi-res (4k) display? This is a known issue currently as they aren't supported by AutoCAD. I suggest you set your font size in Windows to 100% and drop your resolution a bit to see if that helps.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
Hi @Anonymous,
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
HI @Anonymous,
Hello Everyone,
My apologies for not getting back to you helpful people sooner; it's been kind of busy around here! My other programs appeared fine when I needed to select a printer, that's what made it a little more confusing and why I thought there might be some secret AutoCAD setting I was missing. I do not have a hi res display but I did start playing with the text settings in Widows again. I'm not even really sure what I did but it seems to look fine today. It's a little bizarre. Thanks again for the input, I really do appreciate the help!
Sophia
Hello Everyone,
Sophia
