AutoCAD Forum
2016 SPDS
7 REPLIES 7
Message 1 of 8
3913 Views, 7 Replies
2016 SPDS
Hello! Where i can download this module? (SPDS 2016)
2016 SPDS
7 REPLIES 7
Message 2 of 8
ennujozlagam
ennujozlagam
is this the one you looking for? you may try to check it HERE. thanks
Message 3 of 8
in reply to: ennujozlagam
what is this?  CLOWN!
Message 4 of 8
ennujozlagam
ennujozlagam
Sorry for that my apology wrong interpretation . thanks
Message 5 of 8
DarrenP
DarrenP
explain what spds stands for then maybe you will get a better answer
0therwise we are just guessing
DarrenP
DarrenP
Message 6 of 8
DarrenP
in reply to: DarrenP
DarrenP
is this an Autodesk add in or a 3rd party add in?
DarrenP
DarrenP
Message 7 of 8
john.vellek
john.vellek
Hi @Anonymous,
Is this the Russian module that helps for documentation standards?  I have found downloads for 2017 and 2018 but not for 2016 yet. If I find it I will post back.
It might very well be that you can use the 2018 extension with your 2016 but I have no experience in trying to set this up.
John Vellek
Hi @Anonymous,
John Vellek
Message 8 of 8
john.vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Did you try installing the 2018 version? Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hi @Anonymous,
John Vellek
AutoCAD Inside the Factory
