2014: Dashed lines in block editor appear solid when I exit the block editor
Message 1 of 9
So I've drawn a staircase with a break through it, with the remainder of the staircase being colour grey and dashed. It is a block because it appears in many floor plans, so I edit it in the block, make the lines appear dashed, but when I exit the block editor, the grey portion of the stiars appears as a continuous line.
See the attached file.
LTSCALE & CELTSCALE are 1.00, the units are Millimetres, and the scale is 1:1 both in and out of the block editor. Yes I've tried REGEN and REGENALL. PSLTSCALE = 0, MSLTSCALE = 1.
How do I make the lines appear the same way in and out of the stair block?
Replies (8)
Message 2 of 9
Sofia.Xanthopoulou
Hi cam01096,
just change your LTSCALE to 100 Smiley Happy
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 3 of 9
imadHabash
as seen from attached image your origin block is made small one but the other one you send is scaled to become bigger than the origin one. so you have to update your origin block by changing the scale to match your need.
Good Luck...
Imad Habash
Message 4 of 9
imadHabash
i just want to remind (with all respect) that if he change LTS=100 ... this will affect all other linetypes exist in the drawing..
Imad Habash
Message 5 of 9
Sofia.Xanthopoulou
Agreed imadhabash Smiley Wink,
I didn't take that into consideration Smiley Frustrated
I guess @Anonymous you will have to go with @imadHabash's solution.
Thanks for the heads up!
Regards
Message 6 of 9
Sofia.Xanthopoulou
Hi @Anonymous,
I am wondering if any of the mentioned approached worked for you. If so, please mark one of the previous post as accepted solution, so other readers can benefit from your experience, too.
Thank you
Message 7 of 9
massimo.corradi
Since you have MSLTSCALE set to 1, remember that this setting means that your linetypes will be scaled in dependece of the scale.
For example set your model scale to 1:50 and REGEN - your dashed lines will appear. (in some versions REGEN is not necessary - 2014 needs it)
MSLTSCALE (Model Space LineType Scale) will be used when your print from model (scale set in plot window) and in viewports (scale inside the viewport) as you print from layout (paperspace). MSLTSCALE allows therefore to print in different scales and to mantain a representation of the linetype indipendently from drawing scale.
Say you print a sheet with two viewports, one in scale 1:50, the other in 1:10, your linetypes will be shown woth the same proportions in both viewports
Important is that you use REGEN or REGENALL to display linetypes correctly (this is version specific and can be avoided if you have annotative objects).
Message 8 of 9
Dante.Strangis
Community Visitor
Community Visitor
still works...
Message 9 of 9
TomBeauford
As it's affected by the insertion scale besides everything else mentioned here for the few lines I use with linetypes in our blocks I explode them with linexp.lsp by Dominic Panholzer which is just a slight modification of TXTEXP.LSP from Express Tools. Don't have a link so here it is:
;;;    By Dominic Panholzer
;;;    Modified original TXTEXP.LSP from Express Tools
;;;    Copyright © 1999 by Autodesk, Inc.
;;     LINEXP.LSP modifications by XANADU
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;;  External Functions:
;;;     ACET-ERROR-INIT           --> ACETUTIL.FAS   Intializes bonus error routine
;;;     ACET-ERROR-RESTORE        --> ACETUTIL.FAS   Restores old error routine
;;;     ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS   Zoom boundry to include points given
;;;     ACET-LAYER-LOCKED         --> ACETUTIL.FAS   Checks to see if layer is locked
;;;     ACET-GEOM-PIXEL-UNIT      --> ACETUTIL.FAS   Size of pixel in drawing units
;;;     ACET-GEOM-TEXTBOX         --> ACETUTIL.FAS   Returns the textbox for any text
;;;     ACET-GEOM-MIDPOINT        --> ACETUTIL.FAS   Returns midpoint between two points
;;;     ACET-GEOM-VIEW-POINTS     --> ACETUTIL.FAS   Returns corner points of screen or viewport
;;;     ACET-STR-FORMAT           --> ACETUTIL.ARX   String builder
;;;     ACET-WMFIN                --> ACETUTIL.FAS   Brings in WMF file
(defun c:linexp (/ grplst getgname blknm FLTR GLST GDICT SS VIEW UPLFT TMPFIL TBX
                   TMPFIL CNT PT1 PT2 ENT TXT TXTYP PTLST ZM LOCKED GNAM vpna vplocked)
  (acet-error-init
        (list
         (list   "cmdecho" 0
                 "highlight" 1
                 "osmode" 0
                 "Mirrtext" 1
                 "limcheck" 0
         T
; --------------------- GROUP LIST FUNCTION ----------------------
;   This function will return a list of all the group names in the
;   drawing and their entity names in the form:
;   ((<ename1> . <name1>) ... (<enamex> . <namex>))
  (defun acet-txtexp-grplst (/ GRP ITM NAM ENT GLST)
    (setq GRP  (dictsearch (namedobjdict) "ACAD_GROUP"))
    (while (setq ITM (car GRP))       ; While edata item is available
      (if (= (car ITM) 3)             ; if the item is a group name
        (setq NAM (cdr ITM)           ; get the name
              GRP (cdr GRP)           ; shorten the edata
              ITM (car GRP)           ; get the next item
              ENT (cdr ITM)           ; which is the ename
              GLST                    ; store the ename and name
                  (if GLST
                    (append GLST (list (cons ENT NAM)))
        (setq GRP (cdr GRP))          ; else shorten the edata
    GLST                              ; return the list
; ------------------- GET GROUP NAME FUNCTION --------------------
;   This function returns a list of all the group names in GLST
;   where ENT is a member. The list has the same form as GLST
  (defun acet-txtexp-getgname (ENT GLST / GRP GDATA NAM NLST)
    (if (and GLST (listp GLST))
      (progn
        (foreach GRP GLST
          (setq GDATA (entget (car GRP)))
          (foreach ITM GDATA                   ; step through the edata
            (if (and
                  (= (car ITM) 340)            ; if the item is a entity name
                  (eq (setq NAM (cdr ITM)) ENT) ; and the ename being looked for
              (setq NLST                       ; store the ename and name
                      (if NLST
                        (append NLST (list (cons (car GRP) (cdr GRP))))
    NLST
;                          MAIN PROGRAM
  (if (and                                                ; Are we in plan view?
        (equal (car (getvar "viewdir")) 0 0.00001)
        (equal (cadr (getvar "viewdir")) 0 0.00001)
        (> (caddr (getvar "viewdir")) 0)
    (progn
      (prompt "\nSelect lines to be EXPLODED: ")
      (Setq FLTR    '((-4 . "<AND")
                        (-4 . "<OR")                      ; filter for mtext and text
                          (0 . "MTEXT")
                          (0 . "TEXT")
                        (-4 . "OR>")
                        (-4 . "<NOT")
                          (102 . "{ACAD_REACTORS")        ; and not leader text
                        (-4 . "NOT>")
                      (-4 . "AND>")
            GLST     (acet-txtexp-grplst)                             ; Get all the groups in drawing
            GDICT    (if GLST
            SS       (ssget);  FLTR)
            CNT      0
      ;; filter out the locked layers
      (if SS
        (setq SS (car (bns_ss_mod SS 1 T)))
      ) ;if
      ;; if we have anything left
      (if SS
        (progn
          (setq CNT 0)                                 ; Reset counter
          (while (setq ENT (ssname SS CNT))            ; step through each object in set
            (and
              GLST                                     ; if groups are present in the drawing
              (setq GNAM (acet-txtexp-getgname ENT GLST))          ; and the text item is in one or more
              (foreach GRP GNAM                        ; step through those groups
                (command "_.-group" "_r"               ; and remove the text item
                  (cdr GRP) ENT ""
            (setq TBX (acet-geom-textbox (entget ENT) 0))   ; get textbox points
            (setq TBX (mapcar '(lambda (x)
                                 (trans x 1 0)         ; convert the points to WCS
                        TBX
            (setq PTLST (append PTLST TBX))            ; Build list of bounding box
                                                       ; points for text items selected
            (setq CNT (1+ CNT))                        ; get the next text item
          ); while
          (setq PTLST (mapcar '(lambda (x)
                                 (trans x 0 1)         ; convert all the points
                               )                       ; to the current ucs
                      PTLST
          (if (setq ZM (acet-geom-zoom-for-select PTLST))          ; If current view does not contain
            (progn                                     ; all bounding box points
              (setq ZM
                (list
                  (list (- (caar ZM) (acet-geom-pixel-unit))     ; increase zoom area by
                        (- (cadar ZM) (acet-geom-pixel-unit))    ; one pixel width to
                        (caddar ZM)                    ; sure nothing will be lost
                  (list (+ (caadr ZM) (acet-geom-pixel-unit))
                        (+ (cadadr ZM) (acet-geom-pixel-unit))
                        (caddr (cadr zm))
              (if (setq vpna (acet-currentviewport-ename))
                  (setq vplocked (acet-viewport-lock-set vpna nil))
              );if
              (command "_.zoom" "_w" (car ZM) (cadr ZM))  ; zoom to include text objects
          (setq VIEW     (acet-geom-view-points)
                TMPFIL   (strcat (getvar "tempprefix") "txtexp.wmf")
                PT1      (acet-geom-midpoint (car view) (cadr view))
                PT2      (list (car PT1) (cadadr VIEW))
          (if (acet-layer-locked (getvar "clayer"))       ; if current layer is locked
            (progn
              (command "_.layer" "_unl" (getvar "clayer") "")  ; unlock it
              (setq LOCKED T)
          (command "_.mirror" SS "" PT1 PT2 "_y"
                   "_.WMFOUT" TMPFIL SS "")
          (if (findfile tmpfil)                           ; Does WMF file exist?
            (progn
              (command "_.ERASE" SS "")                   ; erase the orignal text
              (setq ss (acet-wmfin TMPFIL))               ; insert the WMF file
              (command "_.mirror" ss "" PT1 PT2 "_y")
            ) ;progn
          ) ;if
          (if LOCKED
            (command "_.layer" "_lock" (getvar "clayer") "") ; relock if needed
          ) ;if
           (if ZM (command "_.zoom" "_p"))              ; Restore original view if needed
          (if vplocked
              (acet-viewport-lock-set vpna T) ;re-lock the viewport if needed.
          );if
          (prompt (acet-str-format "\n%1 object(s) have been exploded to lines."  CNT))
          (prompt "\nThe line objects have been placed on layer 0.")
    (prompt "\nView needs to be in plan (0 0 1).")
  );if equal
  (acet-error-restore)                                  ; Retsore values
  (princ)
(princ)
Now they always display the same no matter what the scale!
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
