2 SCREENS - AutoCad to open on left screen
Wheelie22
Wheelie22
Using AcadE2022 but tested it on 2024 to.
I don't know what is changed but Acad use to open on the screen where I closed it, that was on my left screen.
But now it shows the Startup window on the left (where I closed it) and opens the window on the right screen.
Is there a setting for this ?
FYI
Always use at least 2 screens for AutoCad, but 3 is even better.
Acad / Mail / PDF....
pendean
Community Legend
Community Legend
That's a system setting for most of us, not AutoCAD
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-moves-when...
By chance, is the monitor that you don't want also the WindowsOS default #1 monitor?
get a new system? Add or remove a monitor? You mention 2 and 3 but its not quite clear if there was a change.
More thing to try
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Dialog-box-positio...
paullimapa
FYI if you want StartupWindow  to change to another monitor do the following
https://www.cedarville.edu/insights/computer-help/post/dual-screen-setup-for-desktop-computer-monito...
Paul Li
IT Specialist
@The Office
Wheelie22
Sorry, 1 screen for Acad, 1 for a PDF and another to play a game, I mean look at a mail. 😋
I was at work Monday and even changed the 2 screens HDMI connector on the PC, but that did not change it.
But now working at home (VPN) and now it remembers ? Even AcadE 2024 does it right, on the right screen (in this case the left screen).
