Where are the images that I pasted on my drawing?
Just I can see boxes with a dialogue, this dialogue says "windosw ole objects".
Anyone knows what happened with mi images?
Regards
Regards
Solved by maxim_k. Go to Solution.
Then,would The Autodesk able to make The OLE Objects READABLE in the MAC OSX system later?
I'm in a great need of some sheets in my drawing works.
To my regard.
Thank you.
To my regard.
Thank you.
Hi,pendean.
Thanks for your response and guidence.
Well,i see,i konw how to get over it:Let's forget about the way to find the Windows OLE Objects in MAC.Mission impossible.
So,Tim Cook have one more work now.
Thank you again!
wiki
Hi,pendean.
Thank you again!
wiki
OLE objects do not show in Autocad MAC. - That´s a fact!
But these days I received a drawing that showed the image (OLE OBJECTS) perfectly.
I thought that maybe it was inserted as "paste special" or "OLE bitmap". But wasn't, cause I tried that with a friend that uses Windows.
Do you know what could have been done differently to insert this OLE so that it shows in AutocadMac?
image attached
(1) OLE image perfectly showing in Autocad Mac (sorry, needed to blur it)
(2) OLE not showing
No, I don't have this image file, and it wasn't sent to me with the dwg file.
image attached
(2) OLE not showing
Hi @amandahgmartins ,
Please look >>>>HERE<<<<
Does this method work for you?
Thank you so much Maxim
