Where can I find "Tan Tan Tan" circle command in AutoCAD for Mac?
polisha.abramova
polisha.abramova
 Hello everybody)
I can’t find a “Tan Tan Tan” command to make a circle inside with unknown radius.
Like a small red one on the picture.
Thank you.
@polisha.abramova
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Tan Tan Tan circle command
maxim_k
Hi @polisha.abramova ,
You can:
- use menu Draw -> Circle -> Tan, Tan, Tan:
- use a button on ToolSets Palette:
Or use AI_CIRCTAN command - type it at the command prompt:
Command: AI_CIRCTAN
Enter Tangent spec:
Enter second Tangent spec:
Enter third Tangent spec:
Command:
Or use 3P option inside CIRCLE command and then use TAN object snap 3 times.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
polisha.abramova
Thanks a lot! A’ll check all the options you recommended)
alina.balkanskaia
Hi, @polisha.abramova 😀 Nice to see you in Autodesk Community! I would like to ask you, if @maxim_k advice helped, please, mark his post as the "Solution". Keep the discussion if you are still looking for an answer!
Alina Balkanskaia
polisha.abramova
Hi, may be it’s different in version 2023.
so, I found one way, I created a new panel with Tan Tan Tan command .
maxim_k
Yes, it is another way.
But I have to say that I also have AutoCAD for Mac 2023, the same version as yours.
To show additional options for CIRCLE command you need click and hold on the small triangle on Circle button:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
polisha.abramova
O, thanks again)
