Using formula \U+00B2 (student version)
a37641
Message 1 of 9
a37641
Hi, in student version the formula to write 2 (\U+00B2) ou 3 (\U+00B3) above doesn't work is this correct? When I need to place the 2 above the text using the formula \U+00B2, a ? appears. This has to do with the license being a student license.
Thank you for the help,
Replies (8)
Message 2 of 9
CGBenner
@a37641
Hello, and welcome.  I'm not sure that you need the parentheses on these for superscript.  Try \U+00B2 or \U+00B3 and see if that works.  Good luck!
Chris Benner
Message 3 of 9
a37641
Hello, thank you.
I don't use the parenteses in the software. There many characteres that the autocad recognises but the formulas I write appeares with ?.
It's worth noting that the software I use is for Mac; however, I tested it with a friend who has a standard Mac license, and it works perfectly.
This makes me wonder if it has anything to do with the student license.
Thank you,
Message 4 of 9
pendean
Community Legend
Community Legend
@a37641 Formula being applied where exactly?
And when you tested it on the other computer, the font they were using vs the font you were using on your computer are 100% identical and the same? Was the test done in your own DWG file or their own DWG file?
Your exact AutoCAD year version is...?
Your exact MacOS version is....?
And for the other user, both answers are what?
Message 5 of 9
maxim_k
Hi @a37641 ,
If you need to add superscript in MTEXT, you can use a button on the MTEXT Visor:
Just type " (or 3), select it and pick on "Superscript" button on the MTEXT Visor.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
a37641
I sent my file to my friend and he tested in my file. I use the formula in the attributes and not in mtext.
In the mtext command I can, but I wanted to use it as an attribute.
I leave here an image to help clarify my doubt.
Message 7 of 9
a37641
I tested in Autocad 2024 and 2026, the same for the other user. My MacOS is Sequoira 15.6, and the same for the other user.
Message 8 of 9
maxim_k
Hi @a37641 ,
In order to be able to use unicode hex values, such as "\U+00B2" you have to use text style attributes based on True Type font, but not SHX font as showing on your screenshot.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
CGBenner
@a37641
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
