So pre-2012, the array command created each item in the array as a separate item. Now they are all locked together, and while that has some advantages, I would like to separate them after creation so I can edit each item in the array independently. How do I do that?
Thanks!
Solved by maxim_k. Go to Solution.
You can separate them with EXPLODE command, or just during creation of array select ASsociative option (this vill be saved permanently until you change it back).
You can also edit individual items in array with Ctrl+clicking on item (for move, rotate, scale, erase operations), or you can substitute individual items with the help of ARRAYEDIT command.
Maxim
Welcome to the Autodesk Forums!
@Anonymous wrote:
after explode why do the items not show in shaded view?
I can not reproduce the issue on my side. What OS do you have on your Mac? have you installed latest updates (SP2)?
Do you mean the items not show when "Shaded" visual style is active? Have you tried to use REGEN command? What are these items?
@Anonymous wrote:
also how do i activate ps properties?
Not sure I understand this question. What is ps? Paper Space? which properties you want to activate?
Maxim
If you only want edit block in array
you can copy object array and place anywhere
-explode "object copy"
-enter you block object can you edit
-after edit object save close
-erase all "object copy explode"
your base object array automatically follow last edit object
@Anonymous wrote:So pre-2012, the array command created each item in the array as a separate item. Now they are all locked together, and while that has some advantages, I would like to separate them after creation so I can edit each item in the array independently. How do I do that?
Thanks!
