Unable to select at points when zooming into details - after update
kristinabhalter
kristinabhalter
Hello- I am having trouble after the update. I am unable to select points.  The cursor jumps around the screen when I am zoomed in on a very small detail.
I have also crashed since the update.
I had been running smoothly with the same files yesterday before this update.
acadhelp1
I'm not able to reproduce your issue with zooming with point selection.
I assume it was the AutoCAD 2017.1 update.  Is that correct?
Jon Page
AutoCAD Design Manager
maxim_k
Hi
Please check if you have SNAP enabled - system variable
SNAPMODE should be equal 0 (zero) to turn off SNAP and allow to select points in any place in the drawing area.
You can also toggle SNAP on Status Bar or with F9 (Fn+F9) key, or with Cmd+B shortcut.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hello @kristinabhalter,
Welcome to the Autodesk Community!
Following up on your thread, it appears that several folks have tried to help on this issue.
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Happy PostingSmiley Happy
Sarah Emmsley
Technical Support Specialist
