unable to modify dimensions !!
hey all...
I am using auto cad 2018 on my Mac. I am trying to edit the dimensions of my drawings which I have made mistakenly but I am unable to do so. I have been using windows platform earlier and could modify easily by double clicking the dimensions but I don't know about Mac. could you help me to do so? I have attached a pic and file of simple box. let me know how to change 19 to 20 and 10 to 15. I am asking it in simple drawing so that I could change finally in my project files.
thanks
vishal
john.vellek
Hi @Anonymous,
If you open  (modify) the Standard Dimstyle, and set the precision to 0, is that correcting the value the way you want?
John Vellek
Nope! I don’t want the precision values. I want to modify dimensions. Like as you could see in pic, 19 and 10 are mentioned. So suppose if I need to change them 19 to any number say 15 and 10 to any other number say 20. Means, earlier box is of 19x10 size correct? Now I have modify it and want it 15x20 size. How to do it in Mac?
john.vellek
HI @vshlkumar063,
Your dimensions are associated with the geometry of the box. You can use Stretch to change the size of the box and the dimensions should update automatically.
If you want to override the text in the dimension, simply double-click the text and then type in the new value.
 Please see this video to see the action.
John Vellek
maxim_k
Hi Vishal,
Most likely you cannot modify dimension text by double-clicking on it because of the incorrect PICKFIRST System variable value.
Try to set it to 1. At the command prompt type PICKFIRST, hit Return, then type 1 and hit return again:
Command: PICKFIRST
Enter new value for PICKFIRST <0>: 1
Command:
Now try to edit dim text by double-clicking on it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Maxim's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
