Two Issues - Justify text and Unsupported items.
lgmckenzie88
lgmckenzie88
Hi there,
On the unsupported objects I selected remember my choice on 'Do not show unsupported objects'. How do I get this box back again after clicking it? I'd like to show objects when available.
Justify text - With text normally I could type "Justify" into the command bar then quickly align to what I'd prefer. This option is coming up read only on my Mac which means I need to go into the properties each time to change the text alignment.
Any help would be appreciated.
Thanks.
maxim_k
Hi @lgmckenzie88 ,
About proxy objects:
Try to set system variable PROXYNOTICE=1
About text: can you clarify: "read only"? When and where do you get notification about this?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
lgmckenzie88
Hi Maxim,
The proxy notice was already set to 1, I done this saved then re-opened to no message.
Then when I click enter....
And it doesn't allow me to amend the justification. I need to go to properties to do this.
Lewis.
maxim_k
Try also to set PROXYSHOW=1 and relaunch AutoCAD
About text justification: you are trying to change system variable, which is read only by design.
You can change justification at the command prompt only when you create text.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
