ttf font appears bold instead of regular
Message 1 of 16
Hi Team.
I consistently use Open Sans as my Font type. Somehow it has dropped out of my CAD.
I have removed all Open Sans TTFs from the folder. Regular/Italic/Bold/Bold italic. Restart the Mac. Drop TTFs back in folder. Restart Mac. Then whenever I open autoCAD everything that is meant to be regular comes up Bold in model space even when its properties show it as regular.
When I type styles to check my font the previews show
regular as bold.
Italic as bold italic.
Bold italic as bold
and bold is correct as bold.
Any help would be great thanks!!
Replies (15)
Message 2 of 16
maxim_k
Hi David,
From this thread:
https://forums.autodesk.com/t5/autocad-forum/ttf-font-appears-bold-instead-of-regular/m-p/8464383#M9...
I see you are using 2018 version of AutoCAD.
I tested Open Sans TTFs on my side in 2018 version and everything looks fine.2018-12-13_07-03-30.png
So the problem on your side could be in Open Sans fonts you installed on your Mac.
Can you test fonts in the attachment?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 16
dgorsman
Also, check the Z-axis ordinate.  Non-zero values (may still appear as "0" due to display precision) tend to "puff up" TTF text.  Try changing the Z-axis ordinate of the text to a non-zero number such as 1.0, then back to 0.0.
Message 4 of 16
ChrisPreece
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @maxim_k and @dgorsman provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Message 5 of 16
Hi Maxim
Thanks for you help so far.
I dropped your attached TTFs into my Fonts/TTF folder. In CAD I typed in the Style command and it still shows the regular as bold in the preview window, and in model space.Screen Shot 2019-01-14 at 11.24.47 am.png
Kind regards,
Message 6 of 16
maxim_k
Please verify that you removed all Open Sans font instances from Fonts folder (in both - Home and System Library folders) as well as from Fonts -> TTF folder inside AutoCAD application folder.
After installing fonts I attached to your Home Library -> Fonts folder you should see four Open Sans instances in "Text Style" window:2019-01-14_06-59-11.png
And "Open Sans" font should behave correctly as you see on the screenshot form my system.
OpenSans-Bold.ttf
OpenSans-BoldItalic.ttf
OpenSans-Italic.ttf
OpenSans-Regular.ttf
will give you "Open Sans"
OpenSansExtraBold-Italic.ttf
OpenSansExtraBold-Regular.ttf
will give you "Open Sans ExtraBold"
OpenSansLight-Italic.ttf
OpenSansLight-Regular.ttf
will give you "Open Sans Light"
OpenSansSemiBold-Italic.ttf
OpenSansSemiBold-Regular.ttf
will give you "Open Sans SemiBold"
In Font Book you should see:2019-01-14_07-11-28.png
You may also need to restart your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 16
Hi team. Could I ask you to help me with solving the same problem, please? I use Zirkel Regular and Zirkel Bold on MacBook. Both fonts are visible in the text styles but always appear as bold then... I tried all the solutions mentioned above but nothing works. Would you know what to do? Thank you for your advice!
Message 8 of 16
maxim_k
Welcome to Autodesk Forums!
Hi Miroslav,
Do you use commercial Zirkel font from >>>>this<<<< page?
If yes, then I cannot test the problem you have, because i don't have this font on hand.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 16
Hi Maxim,
thank you for your response. Yes, it's a commercial version of Zirkel. >> Here << I attach the font in ttf format – converted from otf. Could I ask you to prove it, please?
MK
Message 10 of 16
maxim_k
Yes, I have the same issue with this font on my side.
As soon as I add both font files - regular and bold - to my Fonts folder, both fonts shows as bold in AutoCAD for Mac.
But if I add only "zirkel regular.ttf" font, it shows as regular in AutoCAD.
Looks like there is something wrong in font files....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 16
Yes, that is exactly the problem. Thank you for trying, Maxim... Would you have any idea what can be wrong with the font?
Message 12 of 16
maxim_k
Miroslav,
Try attached fonts.
Don't forget to remove all instances of Zirkel font in Font book app before installing new.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 16
Maxim, thank you so much, it works now. Could I ask you, what the problem was?
MK
Message 14 of 16
maxim_k
Miroslav,
The problem was in Style Linking inside Bold variation of the font.
The Bold style was not linked to the Regular.
I was able to repair this problem with Glyphs app.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 16
Thank you very much!
All the best!
MK
Message 16 of 16
maxim_k
Hi @Anonymous,
Can you provide more details about your problem?
Please specify AutoCAD version you have and macOS version installed on your Mac.
And ... don't attach pirated links to your posts.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
