Toggle Isoplane
Toggle Isoplane
Message 1 of 9
Toggle Isoplane
Does anyone know of a shortcut to toggle through ISOPLANE when using isometric snap?
From memory I think it used to be Ctrl+R in the windows version.
I can't seem to get anthing to work other than actually typing in ISOPLANE and selecting either Top, Left or Right
Replies (8)
Message 2 of 9
khedeks
Hi John,
You should be able to use F5 (or Fn+F5 depending on your settings) to toggle ISOPLANE.
Shekhar Khedekar
Autodesk, Inc.
Message 3 of 9
I had to actually go in and deactivate "spaces" from F5 with keyboard preferences to allow this to happen though
Message 4 of 9
khedeks
Fn+F5 should work if you have F5 set to spaces. In the Keyboard section of system preferences you can also use all F-keys as standard function keys, and use Fn+F5 for spaces.
Shekhar Khedekar
Autodesk, Inc.
Message 5 of 9
When spaces is activated it activates when both F5 or Fn+F5 are pressed........unless I am missing something else.
Message 6 of 9
I have a question. I'm using auto cad on my laptop. And I try to use f5 to toggle isoplane but it won't work for some reason. But it works on a regular computer at my school . Do u have any solution to this problem ?
Message 7 of 9
maxim_k
Welcome to the Autodesk Forums!
Do you enable "Use all F1, F2 etc. keys as standard function keys" in Keyboard pane of Mac OS System preferences?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
parthsinghal02
Community Visitor
Community Visitor
Is there any other way to toggle isoplane except for fn-F5  ?
Message 9 of 9
maxim_k
Welcome to Autodesk Forums!
Hi @parthsinghal02 ,
Yes, if you are using AutoCAD 2022, you can assign shortcut to "Toggle Isoplane" macro and then use it to toggle isoplane:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
