AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Title Block scale issue
5 REPLIES 5
jimjsimmons
359 Views, 5 Replies
I am new to AutoCAD & am using AutoCAD Lt 2020 for Mac.  I have been trying for a week to insert a my title page onto a drawing.  From Page Setup Manager I have formated both files to 12" x 18" sheet size.    I tried to inserting the title page as a DWT template and when that didn't work I converted the dwg title page to a dwt block & then inserted it on to my dwg drawing and in both instances the Title page was twice as big (24x36) as the dwg drawing.
I have watched every video & read & re-read Autodesk help pages & cannot find a solution to what is probably somewhat simple?!  Please help me, thank you!
5 REPLIES 5
maxim_k
in reply to: jimjsimmons
Hi Jim,
You already started the discussion about your problem here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/inserting-title-page-template/m-p/9358979#M3728...
Please don't double post - people who want to help you should see the whole story.
So I see that the problem is in scale, as I suspected in previous topic.
Can you share here both of your drawings: main drawing with 12" x 18" sheet size and title block you are trying to insert?
I'll look at them.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jimjsimmons
in reply to: maxim_k
Will do tomorrow. In the interim, my original 3 questions included: 1. How do I erase unwanted dwg & dwt files? 2. I have tried to purge & -purge unwanted & unused blocks with no luck. Any advice to erase these blocks? Thank you for your help.
maxim_k
Ensure that they are not opened in AutoCAD and move to Trash (Bin) using your favourite file manager, for example - Finder.
That means the blocks you cannot purge are actually inserted somewhere in the drawing. Sometimes using -WBLOCK command with * option can help:
http://help.autodesk.com/view/ACDLTM/2020/ENU/?guid=GUID-F26FC1CE-45C9-4C85-9DB9-19B6A597D87B
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jimjsimmons
Thank you for taking your time to review my drawings!
1. I am unable to set up a dwg drawing and title page combination* that is
other than 24x26*?
2. You will see many blocks that I have created that I don't see are used
on my dwg drawings. The only blocks I seem to be able to purge are the
blocks that are supplied by Autodesk in the AutoCAD Lt software? How can I
remove my unused and unwanted blocks permanently?
(possibly I made the mistake of saving them as block *dwg* file?)
3. During the learning process I created MANY erroneous dwg & dwt files.
How cain I remove them permanently?
Thanks again for helping with these issues! Jim
maxim_k
>>>>>1. I am unable to set up a dwg drawing and title page combination* that is other than 24x26*?
I'm waiting for your drawings, you promised to share them.
>>>>2. How can I remove my unused and unwanted blocks permanently?
See my answer here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/title-block-scale-issue/m-p/9363744#M37305
If you mean you have a lot if "blocks" created as separate DWG files, then see #3.
>>>>>3. During the learning process I created MANY erroneous dwg & dwt files. How cain I remove them permanently?
See my answer here:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
