I was working make fonts and it was fine before but now it changed to Black background. Can't see the font style. See attachment
Solved by maxim_k. Go to Solution.
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @maxim_k provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hello, I'm using Autocad LT. I tried downloaded it and it not working. It says "Autocad not found" Any Suggestion.
