AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Tabs missing
6 REPLIES 6
1935 Views, 6 Replies
Tabs missing
I have a drawing that is supposed to have page tabs (in paperspace, obviously).  How do I get them to show?
AutoCAD Lite 2016
6 REPLIES 6
maxim_k
AutoCAD for Mac doesn't have Layout tabs for now. You can use Layouts drop down list on the Status Bar to switch between Layouts.
You can also use Quick View drawings window to change current Layout.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Its a different on the Mac if you are really familiar with AutoCAD on a Windows environment.
To add to this thread look to the below screen shot. In the bottom right corner you can see where the tabs(layouts) of your drawing file should be.
Sarah Emmsley
Technical Support Specialist
in reply to: maxim_k
I don't see a "Layouts Drop Down"
Found the "tabs" button.. it was hidden behind something.
I think I'm all set (for now)
in reply to: Emmsleys
My bottom ribbon disappeared. So I have no layout tabs that are visible. I'm using Autocad lt 2020 on a Mac
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous ,
You need to turn on Status Bar - menu Window -> Status Bar, or Command+6 shortcut:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
