Subtraction Function is not subtracting.
Message 1 of 13
I am a student and have a final project due next monday.  For some reason subtract, union, and intersect GIVE ME FITS...  In this case I cannot get the 3 cylinders to subtract from the object shown (golf putter head).  They are both 3d solids and cannot for the life of me understand why they wont subtract. Can someone help?
-ROOKIE-
Replies (12)
Message 2 of 13
i think i got it...
Message 3 of 13
I might be having the same problem, what was your solution??
Greetings
Len
Message 4 of 13
maxim_k
Welcome to Autodesk Forums!
Do you select objects correctly?
You need at first to select objects you want to subtract from, than hit Return and select objects you want to subtract, than hit Return again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
Thank you, Maxim. That was the reminder I needed!
Cheers
Len
Message 6 of 13
Emmsleys
Hi @Anonymous and @Anonymous,
If you have any further questions post back in the thread. I'd be happy to help.
But if any post in this thread resolved your issue please the select Accept as Solution for appropriate post.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 7 of 13
Hi Sarah,
thanx for your post.
Actually there is one big question I have about AutoCAD for Mac 2016 : why does this program crash so easily and often on my computer? Is it a general problem of the programm or is it my system? I work on a Macbook Pro running on Yosemite and with the following specs:
MacBookPro 6,1
Intel Core i7
2,66 GHz
8GB RAM
NVIDIA GeForce GT 330M with 512 MB VRAM
According to the info I found about system requirements this should work, but it doesn't really.....
How do I select Accept as Solution by the way? Couldn't find a way to do it...
Cheers
Len
Message 8 of 13
Hi Sarah,
hope you are fine.
I would still be interestesd in answers to my two questions. 🙂
Greetings
Len
Message 9 of 13
maxim_k
Hi Len,
Are these crashes reproducible? I mean are you able to perform steps which will lead to the crash?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
Emmsleys
Hi @Anonymous,
Sorry about my delayed response but lets see.. There could be a number a reasons for crashing. Would you mind providing more information?
  • You have all the updates applied? right?
  • Are you running EL Captain or Sierra?
  • Is the crashing happening with all files or specific files?
  • Do you have any crash report numbers?
Sarah Emmsley
Message 11 of 13
Hi Maxim and Sarah,
thanx for your responses.
I am still running Yosemite 😉
I have all updates installed.
The crashes happen in every drawing I make after a certain complexity is reached (which does not have to be very high...)
I attach my current drawing for demonstration.
When in this drawing I try to UNION the two solids the programm crashes completly, needing to be terminated via alt+cmd+esc.
I don't know where I could find crash report numbers, I attach the complete crash report, too.
I would also still be interested in an answer two my other question: How do I select Accept as Solution by the way? Couldn't find a way to do it...
Cheers
Len
Message 12 of 13
maxim_k
Hi Len,
In the drawing you attached to your post the problem is in green 3D Solid object. When I check it with Modify -> Solid Editing -> Check menu command, AutoCAD reports: "This object is not a valid ShapeManager solid."
Command: _solidedit
Solids editing automatic checking: SOLIDCHECK=1
Enter a solids editing option [Face/Edge/Body/Undo/eXit] <eXit>: _body
Enter a body editing option
[Imprint/seParate solids/Shell/cLean/Check/Undo/eXit] <eXit>: _check
Select a 3D solid: This object is not a valid ShapeManager solid.
How did you created this solid?
I was able to reconstruct the solid with the same shape and successfully union the solids from your drawing (see the rightmost solid in the attached drawing).
In the centre I leave solid created myself (red one) not joined to the upper solid.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 13
Emmsleys
 OK to accepted a solution you'll need to be signed in and then you will see the option "Accept as Solution" under each post in your thread.
Sarah Emmsley
