Stupid question from a newbie
Hi, I've had no training and just trying to amend a drawing I have. I've made a couple of very small amendments but when I print it out as a pdf it includes a bit of wall (triangular shaped, circled in red on one of the attachments). But I can't see this on the model (see screen shot). How do I find/delete this?
maxim_k
Welcome to Autodesk Forums!
Hi Matt,
On screenshot you show Model space, but PDF was produced from Layout (Paper space).
So it is yard to say anything about the problem.
Can you share here the drawing itself?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi and thanks for your help. Really appreciate this.
The drawing was prepared by a professional who is now busy with other work. I need to make a couple of minor alterations (to reflect a decision to remove another piece of wall on site). I'm trying to get a black & white layout drawing/general arrangement pdf that I can send to a prospective tenant...and perhaps in due course to send his fit out team a .dwg file.
Thanks Matthew
maxim_k
When I opened your drawing, I saw the problem hatch in the Model space too. Don't know why you have not seen it on your side.
Anyway, I edited hatch (wall fill) and removed spare part.
I also changed color of the layer where hatches (solid fills) was placed to True color in order to get good result with monochrome output.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I closed and opened it several times but couldn't see the problem hatch.
I am really grateful to you. You are very kind.
Matthew
