Step file into AutoCad 2017 MAC
Message 1 of 9
Hi, I'm trying ti import an .STEP file into AutoCad 2017 for MAC, but the only files I can import is, "ACIS(.SAT)" and pdf.
If someone has a solution for this I would be very happy.
Replies (8)
Message 2 of 9
imadHabash
HI,
it's NOT applicable for AutoCAD for mac.... You can only import SAT and DXF (DXB) files.
Imad Habash
Message 3 of 9
Alright, but can I convert it somehow so that I can then import it ?
Message 4 of 9
Alfred.NESWADBA
You might install a Windows version of AutoCAD using Bootcamp (or VmWare or similar tools)
You might try Fusion 360 to convert the STEP file to a SAT fille (which then can be imported into your AutoCAD for Mac.
If it's a one time job then upload the file and I'll try to convert it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 9
imadHabash
AutoCAD Mechanical supports a dedicated command to translate STEP files into the DWG format.
Imad Habash
Message 6 of 9
Yes it is a one time job, it is a school assignment. Many thanks
Message 7 of 9
Alfred.NESWADBA
here it is ...
- alfred -
Alfred NESWADBA
Message 8 of 9
maxim_k
Welcome to Autodesk Forums!
Hi Mathias,
AutoCAD for Mac cannot import STEP files, the only one workaround is to use other application to import STEP and save it in DWG or DXF format, then open saved DWG in AutoCAD for Mac.
This application could be AutoCAD for Windows or Rhino
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
Thank you all for the support and thank you Alfred.NESWA for the file, much appreciated
