Software for rendering of DWG models after AutoCAD
Marsikuss
Marsikuss
I am looking for good software for rendering of DWG models after AutoCAD.
The reason for asking this is a lack of rendering capabilities in current versions of AutoCAD for Mac: no more render command at all, no cameras, background settings, very limited materials.
Having done a 3D model in DWG format, with assigned materials, which software to use next?
Requirements are following:
- must run on MacOS;
- optionally to support materials imported with DWG from AutoCAD;
- free or open source, or at least having a long trial period;
- easy to use, because i am not a professional in CG visualization.
Glad to hear any advices!
Purpose are hobby projects for fun.
Currently i have discovered several options:
- Autodesk A360 cloud rendering, already tried it. Works good, but AutoCAD for MacOS can't set cameras except primary view.
- Blender (must be tricky, i guess).
- SimLab Composer Lite. Looks simple, going to try it soon.
Tomislav.Golubovic
In my experience, I'd say Blender with all your requirements. I was going to say 3DS Max, but its a PC only app.
maxim_k
Hi Kirill,
If it is the only one problem with Autodesk Cloud Rendering, then it is not a problem.
You need to create Named Views (one Named View for one "camera") with VIEW command:
http://help.autodesk.com/view/ACDMAC/2019/ENU/?guid=GUID-6FF3A4E5-9F51-4AE0-ADD1-0B2E0C730DD4
or NEWVIEW command (AC 2019):
http://help.autodesk.com/view/ACDMAC/2019/ENU/?guid=GUID-E6BCEBAC-8680-4431-8BDD-279228010469
Then, after uploading drawing for rendering, you can select to render all views (you can check them in dropdown list).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Marsikuss
Thank you, this is very helpful!
Also is it possible to set background? I can't find it in AutoCAD 2018 (Mac). Maybe new versions already support that.
maxim_k
No, this option still not available in AutoCAD for Mac, even in latest 2019 version.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
