AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Snapping works - but is invisible
4 REPLIES 4
279 Views, 4 Replies
Hi everyone,
I have an issue with Autocad LT 2019 for Mac.
I normally work with the pc version and have never had this issue.
When I am using any kind of snap, it is not showing, but it is working.
e.g. I am trying to snap to the end of a line, the little green snap-box is not showing, but if I zoom all the way in, I can see that the snap is complete.
Sometimes restarting the application helps. Resetting the application does not..
Any suggestions ?
Best, Jens, Denmark.
Tags (2)
4 REPLIES 4
pendean
PICKBOX variable is set to....?
in reply to: pendean
Pickbox is set to 3
pendean
What's your Autosnap maker size?
maxim_k
Hi Jens,
Can you make a quick test:
- draw line
- ensure that ENDpoit OSNAP is active
- start another LINE command and slowly hover crosshairs above the first line
Can you see OSNAP ENDpoint marker?
What if you stop moving cursor above the first line? Does marker appears without delay? Or it start to show after some time?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
