Snap point accuracy issue when drawing polylines
maela_houssen
maela_houssen
Community Visitor
Community Visitor
When drawing a polyline in Autodac, I encounter a precision issue. The software displays the snap point (e.g., an intersection), and I correctly select it. However, when I zoom in, I notice that the actual point registered is slightly offset.
I have an example image where I clearly selected my snap point, but after zooming in, I see that my green point does not align with the blue point as expected at the intersection. I often experience an offset of around 0.33.
Is this a known issue? Is there a setting I can adjust to improve the drawing accuracy?
Thanks in advance for your help!
Maëla
paullimapa
The problem could be that there are multiple intersection possibilities at that location. A better test would be to start a new dwg then draw two lines that cross each other like an X. Then the start point of the third line object snap to the intersection of the two and see if AutoCAD locates that correctly
Paul Li
IT Specialist
@The Office
maxim_k
Hi @maela_houssen ,
Do you have this issue in all drawings? Or just in one?
Can you share here the drawing you took a screenshot of?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
