Snap from Lisp
bedyr
Snap from Lisp
bedyr
I am using a pollyline lisp and it is fillet also. I want to add this lisp snap _from but I dont know how can I do. Anybody can help ?
(defun c:PF (/ pt eLast ent)
(setvar "PLINEWID" 0.2)
(if
(setq pt (getpoint "\nSpecify start point: "))
(progn
(setq eLast (entlast))
(command "_.pline" "_non" pt)
(while
(= 1 (logand (getvar 'cmdactive) 1))
(princ "\nSpecify next point: ")
(command PAUSE)
(or
(equal eLast (setq ent (entlast)))
(command "_.fillet" "_P" ent)
(setvar "PLINEWID" 0)
(princ)
Replies (17)
maxim_k
Hi Bedir,
Do you want to use "from" OSNAP override for all points (vertices) you pick to create polyline?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
I want to draw a polyline along the other(wall). I am doing that offset and fillet command and this is taking my all time.
maxim_k
Isn't it easier to create macro:
^C^C_OFFSET;5 \\;_FILLET;_r;5;_FILLET;_P;_L
with CUI command. In the example above polyline will be offset by 5 units and filleted with radius 5.
and assign it to a button on Toolsets palette, or to menu item (with this option you will be able to assign shortcut for this operation).
The difficulty is that FROM is not an object snap, but rather a Command Modifier, which works differently then standard OSNAP.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
Thank you maxim but it is not working like I want. The wall not just polyline it can be also line. I want to do snap from.
maxim_k
How do you want to specify offset inside FROM command modifier? Do you want to type it from keyboard (you need to specify offset distance and angle), or you prefer to specify it on screen as you showed in screencast?
Actually I have my handmade AutoLISP routine, which creates polyline the same way as PLINE command.
I created it without using PLINE command inside (you are using PLINE command inside your routine).
I think it is possible to put a couple lines of code to it in order to add FROM command modifier to it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
At first command begin first point and ask me that where _from  and then automatically enter ofset. Make this a loop.
maxim_k
You can set offset distance inside routine in order not to specify it each time. But what about the direction of offset? It seems to me you have to specify it for each point separately during creation.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
No it will ask me where _from and I will give it offset side.
maxim_k
I'm talking about offset direction, which means not only side, but also an angle in construction plane. Or do you mean the new line (each segment of new polyline) should be parallel to existing line (segment of existing polyline)?
I have found a topic similar to your question:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-draw-a-polyline-parallel-to-a...
BTW, you may ask your question on AutoCAD Customization Forum:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
But you have to mention that you are using AutoCAD for Mac and can use only vanilla AutoLISP - Visual Lisp is not available in AC for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
I want to do like that. It is in autocad utility and I want to do on autocad.
https://knowledge.autodesk.com/support/autocad-utility-design/learn-explore/caas/CloudHelp/cloudhelp...
maxim_k
Multiline?
I attached multiline library file "test.mln" (inside ZIP archive) with TEST multiline style, which has only one line. If you set justification to ZERO, scale to 1 it will be drawn with 5 units offset from the points you will pick in the drawing.
Here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/how-do-i-attach-a-mln-file-to-autocad-2018-for-...
you can find info on how to load .mln file in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
This is awesome but it is just draw one way direction. how can I change still drawing side duration time?
maxim_k
If you want to draw line on opposite side of the "path" just change scale from 1 to -1, or change direction of picking point on "path".
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
it is difficult do that. when drawing I cant change side.
maxim_k
Is it really difficult? I'm still don't know exactly all functionality of AutoLISP routine (for instance, you didn't mention the side change while you draw, when you originally described the functionality you need). But let's look at side changing closer:
1/ Multiline option.
You can create two macros - one for scale 1 and another for scale -1, and assign them to buttons on ToolSets palette.
Now you when you want to change side, you pick last point on the "path", then pick on button which will cancel current command, call it again and change scale - you only need to specify start point.
So with Multiline we have two steps (pick on button on ToolSets palette and pick start point).
2/ AutoLISP option.
Suppose, you have AutoLISP routine which have all functionality you need.
When you want to change side, you pick last point on the "path", now you shall let now to routine that you want to change side, so you have to type an option at the command prompt and hit Return (two steps). Now you must somehow to show on which side you want to continue creating the line - pick on side with mouse (and that is the third step)
So when you want to change side:
- with Multiline option you have to perform two actions (steps)
- with AutoLISP option you have to perform three actions (steps)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bedyr
I want to like that lisp but in this lisp I couldnt change offset direction. Can we change this for two options?
I will click a point and with mouse action choose offset direction.
(defun c:PF (/ dd mm p1 p2 is nk1 nk2) (setq dd t) (setq mm 5) (setq obj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument obj)) (setq ms (vla-get-ModelSpace doc)) (if (setq p1 (getpoint "\nFirstPoint:")) (progn (while dd (if (setq p2 (getpoint p1 "\nOtherPoint:")) (progn (setq ss (ssget "c" p2 p2)) (if ss (setq is -) (setq is +) ) (setq nk1 p1 nk2 (polar p1 (angle p1 p2) (is (distance p1 p2) mm)) ) (vla-addline ms (vlax-3d-point nk1) (vlax-3d-point nk2)) (setq p1 nk2) ) (progn (setq dd nil) ) ) ) ) ) (princ) )
maxim_k
AutoLISP code you posted here will not work in AC for Mac because it contains VLAX- functions.
Ans I see your request in another post about converting the routine to "vanilla" AutoLISP.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
