AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
single line text edit not working pre or post
2 REPLIES 2
793 Views, 2 Replies
Hi there,
In single line text mode, I am unable to control any options pre or post inputting the text.  Does this happen for anyone else?
Description of problem:
When you type in single text mode (command line; text) no edit options (height etc) are available?
Also, if I go to edit my text after i've typed it, eg command line; DDEDIT, or TEXTEDIT,  still no editing options appear.
As far as I can tell the only way to control your text options is to input text in multi text mode.  Is this normal?
Thanks 🙂
2 REPLIES 2
maxim_k
If you are using single line text (DTEXT command), during creation you can control:
- Style, Justification, height and rotation angle of text at the Command window:
Command: DTEXT
TEXT
Current text style:  "Standard"  Text height:  2.5000  Annotative:  No  Justify:  Left
Specify start point of text or [Justify/Style]:  <-Enter option J or S to set Justification or select Style
Specify height <2.5000>: <- Set height
Specify rotation angle of text <0>:  <- Set rotation angle
Command:
after you create single line text, you can select it in the drawing area and control its properties in Properties Inspector:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thank you , you are right about both, and both works a treat.  Thanks !!
I have found before when drawing using AutoCAD on a PC that you can not edit most of the time from properties (they are greyed out).  I think I had assumed it was the same with AutoCAD for Mac.  That's aweome that you can edit from properties, hopefuly this is the case all yhe time 🙂
