Shape files
Shape files
Message 1 of 11
Shape files
Can I import shape files into autocad for mac?
Accepted solutions (3)
Replies (10)
Message 2 of 11
maxim_k
Yes, you can use shape files (.SHX) in AutoCAD for Mac the same way as in Windows version.
Command LOAD - loads shape file to current drawing, then you can use SHAPE command to insert shapes from loaded .SHX file to the drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
Thanks for the response. I tried to load the .shx file(the only one that it allowed me to load) but was told there was an error reading the file. I downloaded the shape files again to try again with similar result. What now?
Message 4 of 11
maxim_k
I've tested LOAD and SHAPE command with one of my old .SHX files (they are even from DOS version of AutoCAD) and everything works fine with it.
Where did you get yours shape files?
Could you post it here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
I tried with another shape file with similar results. I am using the 30 day trial of AutoCAD for Mac to see if I want to switch from AutoCAD 2006 for windows. It would be good to know if the trial is a full version or not? Any ideas?
Message 6 of 11
dgorsman
Qucik question - are these shape files, as in AutoCAD symbols and fonts; or shape files, as generated by Map3D and other mapping/GIS-type applications?
Message 7 of 11
They would be shape files as generated by mapping/GIS applications.
Message 8 of 11
dgorsman
Ah - bingo.  Plain AutoCAD can't do anything with those, Win *or* Mac.
Message 9 of 11
Thanks for the news about plain AutoCAD.
Message 10 of 11
Which, would leave someone, such as myself, asking if the plain version of autocad can't which version of autocad can?
Message 11 of 11
maxim_k
You need AutoCAD Map 3D:
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticle...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
