Setting the proper scale on an architectural drawing
I created a model of my shop and I want to print it on an 11x17 piece of paper. I want to set the scale to 1/2" = 1'. When I do that in page setup the model shrinks to the corner of the paper... How can I make the printed result be 1/2" = 1'?
The shop is 24' across so I want it to be 12" across when I print it.
maxim_k
Welcome to Autodesk Forums!
Hi Chuck,
I checked and the result is - yes, you can use 11x17 paper (A3) to accommodate viewport with shop plan at 1/2" = 1' scale.
See attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
@Anonymous,
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
I did indeed figure it out. The response to my post wasn't very helpful. Just telling me it's possible didn't really help. None the less, I figured it out. I had to create a new layout the proper size of the page I wanted to print out. I used the included architectural plans style sheet and had to mess with the scale to get it to fit on the page. Then I copied the drawing window making it the right size to fit in the style sheet. Then I messed with the scale on the properties tab to get it to fit properly on the sheet and allow me to include the scale in the details of the drawing.
