I am trying to set a latitude and longitude 0,0 point on my drawing but can't find how to do it with AutoCad 2021. I've looked in the menu and tried typing a command, but the geo things don't appear to be present. If you look at the screenshot below, I dont see "Set Location" anywhere in autocad.
Here is what i see(cant find anything related to geolocation):
Solved by maxim_k. Go to Solution.
A Autodesk deveria parar de negligenciar os usuários de Mac Osx. Deveriam portar ou criar uma versão decente do Autocad, com mesma aparência e recursos presentes na versão para Windows. Além disso, já deveria ter uma versão do Revit. Acordem!
Autodesk should stop neglecting Mac Osx users. They should port or create a decent version of Autocad, with the same appearance and features as the Windows version. In addition, you should already have a version of Revit. Wake up!
