Saving
Saving
traitlibredesign
Saving
traitlibredesign
I have just downloaded 2016 Autocad LT for Mac.
When I save a document it is only saving in 2013 Autocad version, the highest version I can reach in the menu.
Is it normal ?
Thank you
maxim_k
Yes, 2013 DWG format is the latest and highest format.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @traitlibredesign
Following up on your thread, did you have any other questions or issued that you needed help on?
To add:
AutoCAD .dwg file format for 2017 version
Sarah Emmsley
Technical Support Specialist
Emmsleys
Also select Accept as Solution for any post that helped resolves your issue or answer your question.
Thanks.
Sarah Emmsley
