I received a drawing from a surveyor and I want to work on the building plan which is not square to paper space. How can I rotate the entire site plan so that the building plan is square so I can work on it "normally"
Solved by pendean. Go to Solution.
Thank you for your help.
I tried to xref the drawing into a few of my templates but it does not arrive. They survey is decimal. My templates are decimal. I don't understand why not. Could he have some kind of lock on it that prevents being x ref'd?
Brilliant! Thank you.
I Zoomed Extents, "found" the drawing then with the align tool It is now rotated the way I want.
Thank you again.
Jeff
