I just re-installed Acad LT 2021 for Mac trying to get the right-click/ shortcut menu to show up, but to no avail; it should come up when clicking an object while depressing the control key correct? I use ACAD LT on Windows all day, so I'm not sure if I imagined the right-click function being available in the Mac release or not. Thanks in advance!
Solved by maxim_k. Go to Solution.
Hi @xiandavis
No.
Right-click shortcut menu behaves on Mac the same way as on PC.
You need to set SHORTCUTMENU system variable to 11 (default value) and use right (secondary) mouse button to show context menu in drawing area.
Thank you for the quick reply, Maxim! I must have been using a mouse when I was able to display the shortcut menu. It works as you described on my Mac.
