Remove AutoCAD 2013 Macintosh?
Message 1 of 22
Where is the remove AutoCAD application for a complete deletion of AutoCAD 2013 on a Macintosh? There is no such app in the AutoCAD 2013 folder nor is it inside the app package.
Replies (21)
Message 2 of 22
maxim_k
Welcome to the Autodesk Forums!
The "Remove AutoCAD.app" is inside "/Applications/Autodesk/AutoCAD 2013" folder:
Please, check it once again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 22
My uninstaller runs but it doesn't remove my autocad. If you could help me.
Message 4 of 22
maxim_k
Welcome to Autodesk Forums!
>>>it doesn't remove my auto cad
Why do you think so?
Can you see AutoCAD 2013.app in Applications folder after you run "Remove AutoCAD" application? Or you get some messages from "Remove AutoCAD" application and it states that it can not remove AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 22
I'm from Brazil, so i apologize for my bad english.
I run the "Remove AutoCAD" but it doesn't finish running.
The AutoCAD 2013.app still runs perfectly.
I left my mac on all night long and it didn't show even if the AutoCAD was
being deleted.
I installed the new version 2015, but the 2013 version still remains on my
computer.
It would be nice if you could resolve my problem.
Miguel.
Message 6 of 22
maxim_k
Before removing AutoCAD you must ensure that it is not running:
1. Start AutoCAD 2013, than use menu "AutoCAD 2013" -> "Quit AutoCAD"
2. Now start "Remove AutoCAD 2013" application from Applications/Autodesk/AutoCAD 2013 folder.
3. Now make screenshots of each step in removing AutoCAD until it finishes (or stop to work) and post them here please.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 22
I have this same problem. I have quit all open sessions of AutoCAD, yet the uninstaller program never completes the uninstall and hangs on this point of the process:
There is no way to click "Continue". The uninstaller package remains responsive as I can click "Back" and quit it, but cannot get it to complete the uinstall process. Know of any solutions?
Thank you!
Message 8 of 22
Huh, oddly installing AutoCAD for Mac 2015 allowed me to successfully remove the 2013 version.
Message 9 of 22
Hi
I have the same issue, the uninstaller does not want to quit. Have you been able to resolved it.
YD
Message 10 of 22
maxim_k
lianeoyang wrote that
"installing AutoCAD for Mac 2015 allowed me to successfully remove the 2013 version"
So you can try to download AutoCAD 2015 trial version, install it, than uninstall AutoCAD 2013.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 22
Thank you Maxim, your advice work
Do you know the when AutoCad 2013 for Mac service pac will be release, which will allow us to be compatible to Yosemite OS
Thank you
Yanic
Message 12 of 22
maxim_k
Hi Yanic,
No I'm not aware of this.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 22
i have the same issue.  would be good if someone can help.
i have a trial full autocad 2013 on my mac, and a licensed version of 2015LT, i want to remove the 2013 version and the unistaller freezes as per lianeoyang screenshot
regards
Message 14 of 22
maxim_k
If you have OS X 10.10 (Yosemite) on your Mac - have you true to install AutoCAD 2013 for Mac Service Pack 3 from here:
http://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2013-...
According to README for this Service Pack, which you can find here:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2013_and_AutoCAD_LT_2013_Fo...
SP3 installation resolves:
"General Service Pack Updates
The following general changes and improvements have been made:
Plot
  • Image corrupts in plot result.
Yosemite
  • Two fingers moving on trackpad trickers zoom instead of pan.
  • Uninstall hangs."
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 22
i will try it and let you know.
thank you
Message 16 of 22
this thing is completely broken I already installed the SP3 and still the problem persist. I feel like what I installed on my mac is cracked program, I used to have windows and **** like this always happen...
Message 17 of 22
Since up to now I cant find an option to edit my last message, I can Confirm The solution:
  1. as mentioned earlier in this thread, installing autocad 2015 for mac does help. (trial version works great)
  2. following the installation, just say that you want to try the 30 days option.
  3. go to the autoad folder again, and look for the 2013 folder, open the "remove autocad icon", wait 2 seconds, the screen will come and go and then bum!, deleted.
  4. then I deleted the autocad2015 for mac trial, because lets face it you are here because you want to delete the thing.
  5. Celebrate and end the frustation.
Note: if you have problems with earlier or other versions theres a chance that this could work, give it a try.
Cheers.
Omar.
Message 18 of 22
Hi, I am experiencing the same issue for a long time. I am running on El Capitan and my AutoCAD 2013 does not remove, tried to download Service packs, but it is not possible in this version of OS. Then downloaded AutoCAD 2016 for Mac but it still did not allow me to uninstall 2013 version.
Could you help me please, what might be my otions uninstalling it?
BR,
Eva
Message 19 of 22
maxim_k
Hi Eva,
This is knowing issue.
The only way to remove AutoCAD 2013 on Yosemite and El Capitan is to remove it manually:
Please just find the AutoCAD 2013 related files in the following folders and remove them.
· /Applications/Autodesk/
· ~/Library/Application Support/Autodesk/
· ~/Library/Preferences/
If you need further assistance, let me know here.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 22
Hi, thank you! Successfully uninstalled ACAD LT form my Mac.
