Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Recover sv$ (autosave) files
12 REPLIES 12
Message 1 of 13
94012 Views, 12 Replies
How can I find the "tmp" folder where autocad allocates the autosave files so that I can recover one after a sudden crash?
I just can't find the folder in finder!
Thanx
12 REPLIES 12
Message 2 of 13
maxim_k
you can find "autosaved" files in "/private/tmp/", because tmp is just an alias (link) to this folder. Also note, that private folder is "hidden folder", so you have to enable Finder to show hidden files.
I think, that  it will be interesting for you to read this: Changing the Autosave File Location in AutoCAD for Mac
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
in reply to: maxim_k
yeah, that helped. I changed the location of the temp files so I can access them easier...the problem now is that autocad crashes quite a lot... 😞
Message 4 of 13
I read the article you suggest, and was able to change the folder where my autosave files are saved, but i still can't find the tmp folder where my lost work may be... I enabled finder to show the hidden folders, but it wasn't enough...
HEEEELP PLEASE!
Message 5 of 13
In the windows explorer bar type %TEMP% and it will bring you to your temp folder. You will need to have hidden folders and files showing in Tools-> Options.
~ Rhea
Message 6 of 13
maxim_k
~ Rhea
Sorry, but here is Mac world - no Explorer, no Tools->Options...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 13
Well I came across this when I was looking up .sv$ files and im on Windows so it may help a non mac user in the future.
Message 8 of 13
Is there anyway to recover the sv$ file if I never changed the autosave loaction from the default and I stupidly already restarted my computer? I just read somewhere that the temporary folder where AutoCAD dumps the sv$ automatically empties when the computer is restarted,
I've lost so much work because I didn't save my progress as I went like I should have... I'm sure the sv$ would be there waiting for me somewhere if I hadn't already rebooted.
Please tell me there is some way to get it back!
Message 9 of 13
maxim_k
If you are using AutoCAD 2012 or 2013 for Mac, then look for your sv$ files in "~/Documents/Autodesk/Autosave/" folder (Documents folder inside your home folder)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
Hello all,
I've saved by mistake an older version of my project file over the new one - three weeks of work gone in a second..
i've trued looking for the .sv$ files in the autosave file, in the ~tmp folder (after enabeling hidden files) but without any succes i could only find the .sv$ of the files which are open
I need help here!!!
thanks
Hagay
Message 11 of 13
maxim_k
@Anonymous wrote:
i've trued looking for the .sv$ files in the autosave file, in the ~tmp folder (after enabeling hidden files) but without any succes..
Hagay
If you are using AC 2011, and there are no auto-saved files in "/private/tmp/" folder, then you loose them forever, because the contents of "/private/tmp/" folder erased on each system reboot.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
I have not logged out and I am on a university computer so i cannot show hidden files? how can i recover the file i was working on if i have saved before but not recently. when i open the file it does not recover it just goes to the old file. PC and 2014 edition
Message 13 of 13
maxim_k
Welcome to Autodesk Forums!
Although it is AC for Mac forum let me try:
What do you see in Recover manager?
When you are trying to open your damaged file - does AutoCAD asks about Recover?
Or you just not saved file before closing it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
